Yea with the newest version you don't need to CS every time you startup, assuming your backup battery is still good(they last for years so it should be).
Post up some pics when you get it, I'd love to see it. I hope all goes well in the move and power up!
If it prompts you to set parameters at startup there should be a list of startup parameters in the control cab or on the inside of the pendant, just enter "setp" at the command prompt and enter that data and you will be back up and running.
Fadals manuals can be downloaded from their site if you did not get a set. |
