Old 06-16-2005, 01:22 PM
Al_The_Man's Avatar
Al_The_Man Al_The_Man is offline
Originally Posted by DSL PWR
I have 2 westamp motors and the name plate is as follows:
type MT :231
Cont Current : 6.5
Max Voltage : 100v
Pulse Amps : 34
Tach : 7.0 volts/1000rpm
Insul : F
I ripped the top cover off of the motor assm. and saw 2 heavy wires (#10) and 2 light wires (#16). The heavy ones would be for the drive pwr, but what are the light one's for?
Thats what you get when you answer in a hurry, I was just on my way out and realized I had given you a bum steer, the two small wire are the tach wires which you should not need on modern amps as they are used in the current mode rather than velocity mode.
I also have a third motor that I belive is a stepper. The only thing I could get off of the nameplate is:
Electro Craft
Part# 0652-00-004
I need to know the specs of this motor.
I have the listing for the 0642 which is a DC motor, often ElectroCraft supply OEM's and put a house number on, so the only way to identify is by physical dimensions and obtain as many electrical characteristics as possible.
On top of each motor is an encoder, I think it is a 500 count. I found it on the company's web site but most of it is greek to me.
BEI Motion Systems Company
Model# : L25G-F2-SB-500-ABZC-8830-LED-SC18-S
Part# : 924-01008-1195
Will these encoders work with a Gecko or a Rutex board?
These are 500 count/rev line driver with ABZ pulses complementary outputs, you should be able to use just one channel if thats all that the amps require.
I also have 3 Bison gear boxes, the 2 on the westamps are 30.6:1, and the one on the stepper is 40:1.
What lube if any is used in these?
They can be used in a CNC application but only if they are zero ( or low) backlash type.
The lube requirement you would have to get from the Bison web site.
I would like to find a place that STOCKS the following items in Alberta Canada, although western Canada would do (shipping and brokerage fees from the U.S. ups the cost too much). I've found distributors in Canada for some stuff, (according to the web sites of the mfg's) but when I phone the store (ex: Bearing and Transmission) they have no clue about gear rack etc... So here is my wish list:
Most of those items B&T should be able to provide, but BC Bearing supply Boston Gear rack, there may be a one near you, or Calgary.
If you want AMP connectors, the CPC style are one of the most economical for quick disconnect and resemble the military MS style, Electrosonic supply them, the pins can be soldered so you do not need an expensive crimper.
Hot, young naked blonde women
Working on it
