Originally Posted by posix Hello there James.
C5 and C6 are 2.2uF on the schematic, however you provide 4.7uF in your kits. Also Q5-Q8 are BC337 on the schematic yet you show TO-92 in your kit. Which one is the correct component? |
Those components are not critical and so either is correct. The values shown on the schematic are "ideal" but the components supplied with the kit work perfectly and happen to have been easier to source.
BTW: TO-92 is a case size not a transistor type, and in fact the transistors supplied with the kit are actually BC337 in TO-92 cases. But the transistor is not critical and the standard 2n replacement for a BC337 could be used instead.
Originally Posted by posix P.S. as far as those pictures are concerned, you'll get them from me when I'm done making the PCBs - laying out and routing this tiny board on a single layer takes time with eagle  |
I'm looking forward to it!
