If you use a greenfield tool they will do the program for you. I have a program to do pipe threads if you need it. To get it round you need to move out on your arc move per quadrant to keep the thread form correct. I do them all the time with no problem. I run pro manufacturing and proe does not do pipe threads so it takes so modeling to get the job done. Let me know if you need the program and I can post it here or send you a copy. As far as the "G33" I can't help you there. |
