Also make sure if you need to tap off 120 volts for relays or such that you don't use the "high" leg, ie all rotary convertors I have build will have 220-240v from leg to leg but from leg to ground you will have @120v on 2 legs and 240v on the third leg. Will fry a 120 relay pretty fast! |
