Does your machine have a wire break light? A lot of times there are lights bunt out on front panel makes it hard to be sure the 4 functions are on.
If so. Then make sure the wire break switches are working.
That said; In the back on the bottom of the cabinet there is a big transformer looking thing. Thats your DC generator. On top in the middle you will see a terminal strip w/2 wires. (Those 2 wires go to the starter mounted on the right. Thats the starter that makes the click you here when you turn the power on.) Clip in a meter set at DC there. As you change your voltages on the front the output here will change. There will only be 3 I think. ? 90-100-110 VDC? There about. |
