I think Mcmaster -Carr rounds of the 5 tpi to the nearest 64th. I don't think the 13/64 is the actual lead, from what I've heard. I'd check that out first to see if it helps.
The Xylotex is probably a little small for that size machine, but if you're going slow enough you should be OK. What Feed speed we're you running at?
__________________ Gerry
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
