I have attached my file for anyone (with Onecnc XP series) to look at.
I do not believe that the default Bandit2 or Bandit4 posts are set up similarly to mine. In fact, let me know if you have a problem even opening my post in case of file incompatability. I am running a beta test version right now, is all, and I cannot guarantee backwards compatability.
For sure, the placement of the "/" for rapids will not work with your current version, but you can edit those out as I am sure they would not be useful to you. Be warned that Bandit post processors are quite far off the mainstream, so I wouldn't recommend that you use it, other than to run it to see how it works. |
