Rekd,
I guess they do now?
Unless you decide to delete it, I've read it now, it's ok to do that, Just kidding.
Hopefully they will leave it as it is. That extra layout for the solids is one expense that could be delayed (until later) if you wanted to purchase MC for programming, and needed to receive DWG files from Autocad, (which is one of my problems in considering software). That extra money is one of the reasons I'm still evaluating other software.
I'm sure the Solids will be necessary for most shops eventually, and this hole would allow shops to use "MasterCam" as you described, and then add on solids later when they needed solids for the applications it was created for.
You could call it a good "Public Relations" decision. |
