Actually I tore down the original switch. Its not functionable anymore. So if I understand, I can use the toggle switch to connect to 2 of the 4 wires possibly? And to find out which 2 to use would be the 2 that send a signal to the mother board? On an earlier test 2 of the 4 wires read around 110 volts ac, and the others read around 8 volts I believe. I'm trying to determine which 2 I could connect to the new toggle switch. definitely an "AT" style supply. |
