Old 06-09-2005, 09:07 AM
Al_The_Man's Avatar
Al_The_Man Al_The_Man is offline
Originally Posted by FLUTE HEAD
Yes, I soon discovered that pc p.s. switches are not just toggle switches. "AT" 4-wire style power supply)
I have always used regular switches, even a relay, I suspect that you have wired a double pole switch and got the connections wrong so that it is a dead short across the 120ac, test the input with a meter. it will be very low resistance but not as low as a dead short will show, compare the readings to your meter leads shorted (resistance scale). If this is what happened then you will have done no damage apart from maybe welding the contacts on the switch.
