Did I blow my power supply in pc? | | Ok this is what I did. My pc power switch went out so I decided to go with a regular toggle switch and ended up tripping my breaker. I would now like to test the power supply on computer. Without switch connected could I check for 5v, 12v levels at mother board? Or do you think the second I try to plug up the power input to pc the breaker will just trip again. Whats a good way to check for this? Yes, I soon discovered that pc p.s. switches are not just toggle switches. What kind of damage is likely to have happened to computer.
("AT" 4-wire style power supply) |
