Old 06-08-2005, 11:32 PM
CNCadmin's Avatar
CNCadmin CNCadmin is offline
Site Owner
CNCadmin has disabled reputation
Major Upgrade coming
CNCzone will be undergowing a major forum software upgrade somtime this month.
Here are a few new features-
# ImageMagick 6 support. This is experimental and relies on you to have ImageMagick properly installed. Image Verification requires ImageMagick to have been compiled with Freetype support and possibly have Ghostscript installed as well (under Unix).
# Option for user to specify their own event start / end times.
# Custom avatars and Profile pictures will be automatically resized to the maximim allowed image sizes (when possible). If you are using ImageMagick then they can also be automatically converted from .BMP, .PSD, .TIFF, and .PDF
# Each image attachment type can be set to generate thumbnails instead of All Images or None.
# Each attachment type has an "Open in New Window" option now.
# Language Chooser
# [attach] BB code that allows you to reference an attachment directly in a post. Usage: [ attach ]attachmentid[ /attach ] or use the attachment drop down in the WYSIWYG and Enhanced editors to insert your attachments.
# [noparse] BB code that allows you to disable BB code parsing in a specific section of a post.
# Word wrap no longer applies to text in code/php/html tags.
# BB code parser automatically fixes bad tag nesting
# The unfinished Event Reminders feature is finally working. You select how long before an event that you would like to be reminded and vBulletin will send you an email reminding you.
# New Can Upload Animated GIF permission for custom avatars and profile pictures.
# Attachments can now be uploaded from an URL as well as from the user's computer.
[b]I have also turned the "similar Posts" feture that is located on the bottom of thread views.[/b]
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
