Hey Guys,
I am so excited I have to share this!
This is EASY to make. Even if you don't have a lathe you should still be able to get this made using copper tubing.
I have been trying to get stickers cut off of my mill for quite sometime. I finally got a good holder made that works very well and is rather cheap to make. However, the cut depth of the trim sheets is 0.08 mm and if the table is not "just right" or your backlash, the sticker is not "cut out." I am using an MDF top on my K2 router. Overall it is straight but still any irregularites are shown through peeling the sticker.
Here is a weighted holder using my Take 5 blade holder. Basically it is a tube sliding in a tube with the right amout of weight to keep the tool into the material. It works great! The g-code is cut with no offset.
CLICK HERE and got to the Take 5 and Weight holder.
I hope you guys decide to make one...it is really cheap and easy.
taus
