Fanuc 18M 414 Servo error | | We have a Kao Ming VMC with Fanuc 18M controller. I get a
414 Servo Alarm - X axis detect error. In the diagnostic parameter 200,
the HCA bit (bit #4) is 1 - which is abnormal current Alarm. The LED on
Servo glows with 9 (but it seem for HC it should be 8). Everything else does not have problem. The alarm comes only when there is actual cutting going on. Some time it comes soon after the cutting starts, some times it take couple of minutes. Spindle load is only around 40%. But if the program is run dry (just increasing the height so that there is no cutting), there is no problem. Once the alarm comes, it goes off
(only) when the machine power is switched off completely. What can be the problem?
Thanks,
Shrirang |
