Originally posted by HuFlungDung The trick is to be absolutely certain that you are not going to loose gouge protection by blanking the surfaces. If the surfaces are actually inaccessible to the tool (such as the underside of something) then you could safely blank those. |
Now that is somthing I had not thought of but would have painfully been made aware of real quick. I bet that is somthing you learned from personal experience
