Were is a nice 24 x 36 to consider. I am building one. Very rigid and promises to have very low amounts of "slop" in the system by using Hiwin linear slides and Ballscrew and Actuator, zero lash lead screw and nut assemblies. With an Aculux laser digitizer, Mach1 NC controller software, Visualmill 4, and Rhino 3D I will be in the door for about $7200 . Also uses NEMA 34, 521 oz. steppers and Gecko drivers.
Should be a cutting motorscooter. Check it out! |
