Old 11-11-2010, 08:09 PM
ParkerMillguy ParkerMillguy is offline
ParkerMillguy is on a distinguished road
Finish cut at final depth
Originally Posted by dcchip View Post
I use 2.5 setup and boss (outer loop, convert to loop)then click on edge and if I can remove all material with my rougher or let offal just flop off i use the fine selection twice. Once for stepping down leaving material on the sides say .01 then my second one for pass @ full depth leaving nothing on sides. Now if your looking for one of their selections to do this let me know as I havnt been able to find. I have read that u can make your own processes that will default to the way you prefer to machine but I havnt made it that far myself.
Edit Definitions/Contour tab/Side Parameters Box: Click Settings button/Finish Passes Box: Final Cut amount (How much you want to take for a finish cut) Then click "Single Cut Depth" check-box to only machine at final depth.
