Old 11-09-2010, 01:34 PM
nigjoe nigjoe is offline
nigjoe is on a distinguished road
Before the 24ft bed Biesse came along I ran on a 442 Heian twin head, twin 63"x63" tables with a 2" seperation, I use a m40 to lock the tables in the program. Because the heads are fixed in the gantry and the tables move in y I have only 12.5" at the back of the machine where the stringer will not hit the beam uprights, if I ran the stringer in the front it would hit the saftey gates on either side of the table. I usually set the 0 of my program at my pinstops bottom lh side of the tables, so in this case I offset my part X-65" Y63 from my right hand table as I will machine every thing with head #1 (head seperation is 800mm) I make my tool paths in Mastercam, create the first program, save it take my second DXF and create the program. I cut and paste the programs together inserting an optional stop and releasing the vacumn so I can move the part, turn the vacumn back on, then restart the program to finish. If u r wondering, I have sub programs set up in the controller I made to put pins up/down, bring the machine back to home, turn vacumn on/off, they r the p#s. Here is an example of code, (I cut all the crap out) and a couple of DXF's
Hope this helps u out.
Cheers
O3499(7.375R X8.25RX13RISERS LH CLOSED PT1)
(MC9 FILE - U:\BOLTONPART\STAIR FOLDERS\STRINGERS\7.375 RISE X 8.25 RUN\7.375R X8.25RX13RISERS LH CLOSED PT1.MCX)
(POST - )
(PROGRAM - 7.375R X8.25RX13RISERS LH CLOSED PT1.NC)
(DATE - DEC-08-09)
(TIME - 10:10)
(T2 - 1/2" COMPRESSION - H2 - D18 - D0.5000")
G08 P1
M40
G91 G17 Y0.
P9000
M211
M232
M213
M234
M400 (CANCEL ALL HEADS SELECTION)
M76 (BRUSHES DOWN)
M401 (SELECT HEAD 1)
M06 T2 (1/2" COMPRESSION)
M03
M91 S18
(MAX - Z2.)
(MIN - Z-.375)
G00 G90 G54
X-6.4661 Y51.6833
G43 H2 Z2.
Z.25
G01 Z.1 F400.
G02 X-5.6739 Y52.2935 Z.0177 I.3961 J.3051
X
G00 Z2.
G91 G28 Z0.
G28 X0. Y0.
M92
M95
M214
M98 P9300
M231
M233
HAND MODIFIED CODE)
G91 G28 Y0
M0(MOVE PART BEFORE RESTARTING)
(END OF MODIFIED CODE)
7.375R X8.25RX13RISERS LH CLOSED PT2)
(MC9 FILE - U:\BOLTONPART\STAIR FOLDERS\STRINGERS\7.375 RISE X 8.25 RUN\7.375R X8.25RX13RISERS LH CLOSED PT2.MCX)
(POST - )
(PROGRAM - 7.375R X8.25RX13RISERS LH CLOSED PT2.NC)
(DATE - DEC-08-09)
(TIME - 10:12)
G08 P1
M40
G91 G17 Y0.
P9000
M211
M232
M213
M234
M76 (BRUSHES DOWN)
M03
M91 S1
(MAX - Z2.)
(MIN - Z-.375)
G00 G90 G54
X41.62 Y55.8634
G43 H2 Z2.
Z.25
G01 Z.1 F400.
G02 X42.6004 Y55.6664 Z.0177 I.4902 J-.0985
G40 X58.5661
Z-.125
G00 Z2.
G91 G28 Z0.
G28 X0. Y0.
M92
M95
M214
M98 P9300
M231
M233
M30
File Type: dxf 7.375r X8.25rx13risers lh closed pt1.dxf‎ (19.1 KB, 28 views)
File Type: dxf 7.375r X8.25rx13risers lh closed pt2.dxf‎ (16.6 KB, 19 views)
