Originally Posted by Chris D $2.00 each for those tools is a bit much - check out www.use-enco.com to see what new tool bits would cost.
You can purchase blank, HSS stock, or even carbide tipped, pre-ground tool bits.
Machine looks nice though!
Chris |
Chris
Your joking aren't you. I'd rather give 5.00 for a pre ground tool than 50 cents for a new one. Whats your time worth. I almost always buy used preground tools as they are usually top grade tool steel as oposed to inport who knows what for a 1.00 or so a bit. After spending a few dollars on used tools over the years I rarely have to start a new tool forom scratch no mater what the need. And most often they were ground by someone that knew what they are doing.
Garry
