Thread: Backup Script..
Old 07-16-2003, 11:53 AM
Rekd's Avatar
Rekd Rekd is offline
Rekd is on a distinguished road
Backup Script..
Here's a handy script a few of us at eMastercam created to do
backups of current files to a different folder, using a date/time
stamp.
It uses Winzip's Command Line Interface to add the backup file to
a .zip file then delete the backup file.
You can substitute winzip with your archiving program if it accepts
command line arguments. Just make the needed changes to
the "Public Const" section towards the top of the script to assign
your Backup folder and your compression program.
I posted it here instead of the Tech Articles area to preserve
formatting.
Code:
'//        Author:   Matt Finley mfinley<at>rolingem<dot>com
'//                  Original script by Mick George.
'//          Date:   16/07/2003 08:07 AM
'//     File Name:   _Archiver.vbs
'//   Description:   Makes a backup of the current MC file to the folder specified.
'//                  Use Winzip with command line interface to compress then delete backup file.
'//                  You can get the command line interface here: http://www.winzip.com/wzcline.cgi
'//      Comments:   This script uses wzzip.exe, (WinZip's command line interface) to compress
'//                  the backed up files. Ensure the correct path and arguments for the compression
'//                  you wish to use are entered below. You need to use the truncated name for
'//                  long path names that contain spaces when calling wzzip.exe.
'//                  This script uses -m and -ex to delete the original backup file and
'//                  to use maximum compression.
'///////////////// My Constants /////////////////
Public Const fsoDRIVE_UNKNOWN = 0
Public Const fsoDRIVE_REMOVABLE = 1
Public Const fsoDRIVE_FIXED = 2
Public Const fsoDRIVE_NETWORK = 3
Public Const fsoDRIVE_CDROM = 4
Public Const fsoDRIVE_RAM_DISK = 5
Public Const DEF_CENTERED = "         "
Public Const DEF_ERRLOG = "C:\Your Folder\Backups\McScriptErr.log"  ' Path and file for error log
Public Const strZipPath = "C:\Progra~1\WinZip\wzzip.exe -m -ex" 'Path and options For compression
Public Const DEF_BACKUP_DIR = "C:\Your Folder\Backups"  ' Backup folder
Dim strName
' -- Start Script
Call Main()
' Sub Declaration
Sub Main()
On Error Resume Next
Dim strBackupPath
Dim strOriginalPath
Dim FSO
Dim strYear
Dim strMonth
Dim strDay
Dim strHour
Dim strMin
Dim C
  C = Chr(34) ' variable for " (double quote)
  Set FSO = CreateObject("Scripting.FileSystemObject")
  ' -- Make sure theres a disk in the floppy drive
  ' -- Check to make sure backup folder is valid
  If FSO.FolderExists(DEF_BACKUP_DIR) Then
    ' -- Make sure we have a drawing to save
    If Not IsDrawing Then
       ShowString "No current drawing" & DEF_CENTERED
       ' -- Bail
       Exit Sub
    End If
      ' -- Store current drawings name
      strOriginalPath = GetCurrentFileName
      ' -- Format a time and date stamp and strip illegal chars
      strYear = Replace(FormatDateTime(Date, vbShortDate), "/", "")
      strHour = Replace(FormatDateTime(Time, vbShortTime), ":", "")
      ' -- Build fullpath
      strBackupPath = AddBackSlash(DEF_BACKUP_DIR) & FSO.GetBaseName(strOriginalPath) & "_" & strYear & "_" & strHour & "." & FSO.GetExtensionName(strOriginalPath)
      Call ClearMenuAndPrompts
      ' -- Display current file in prompt area
      Call WriteString("Backing up file, please wait...")
      If SaveMCAs(strBackupPath, True) Then
	  strName = strZipPath & " " & C & strBackupPath & ".zip" & C & " " & C & strBackupPath & C
      Call ShellAndWait(strName, True)
'         ShowString "Backup to " & DEF_BACKUP_DIR & " complete" & DEF_CENTERED
      Else
         ShowString "Could not backup file to "  & DEF_BACKUP_DIR & DEF_CENTERED
      End If
      ' -- Switch back to original file
      Call SaveMCAs(strOriginalPath, True)
      Call RepaintScreen (True)
  Else
     ShowString "Folder " & DEF_BACKUP_DIR & " does not exist!" & DEF_CENTERED
     Exit Sub
  End If
  If Err Then Call TrapError("Sub::Main", Err, True)
 Set FSO = Nothing
End Sub
' Sub Declaration
Sub TrapError(sSource, objErr, bLogIt)
     Dim sMSG
     Dim sLogError
     Dim FSO
    sMSG = "Following error occurred in this script:" & DEF_CENTERED & vbCrLf & vbCrLf
    sMSG = sMSG & objErr.Description & DEF_CENTERED & vbCrLf
    sMSG = sMSG & "Number: " & objErr.Number & DEF_CENTERED & vbCrLf
    sMSG = sMSG & "Source: " & DEF_CENTERED & sSource
    ShowString sMSG
    If bLogIt Then
        sLogError = "Error " & objErr.Number & " in " & sSource & ":" & vbCrLf & objErr.Description
        Call WriteLog(sLogError)
    End If
    objErr.Clear
    Set objErr = Nothing
End Sub
' Sub Declaration
' Function Declaration
Function GetScriptEngineInfo()
  Dim s
  s = ""                ' Build string with necessary info.
  s = ScriptEngine & " Version "
  s = s & ScriptEngineMajorVersion & "."
  s = s & ScriptEngineMinorVersion & "."
  s = s & ScriptEngineBuildVersion
  GetScriptEngineInfo = s   ' Return the results.
  If Err Then Call TrapError("GetScriptEngineInfo", Err, True)
End Function
Function CheckDrive(sPath)
  Dim FSO
  Dim fsoDrive
  ' -- Get the "A" drive
  Set fsoDrive = FSO.GetDrive(sPath)
  Select Case fsoDrive.DriveType
         ' -- Only interested in a Floppy drive...
         Case fsoDRIVE_REMOVABLE: CheckDrive = fsoDrive.IsReady
         Case Else
              ' -- Force failure
              CheckDrive = False
  End Select
' -- Clean up
Set FSO = Nothing
Set fsoDrive = Nothing
If Err Then Call TrapError("Function::CheckDrive", Err, True)
End Function
Function AddBackSlash(sPath)
If Right(sPath, 1) <> "\" Then sPath = sPath & "\"
AddBackSlash = sPath
End Function
Function IsDrawing()
Dim Ret
Ret = StartDBSearch(mc_alive, -1)
IsDrawing = Ret
End Function
'Rekd teh sharing
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
