Scott,
Still no way to step backwards through the code just forward.
I would like to be able to just close a file.... File / Close.
The following file displays perfectly in Discriminator (
www.cncedit.com) except for G13 which Discriminator does not support. It does not display even close to properly in NC Plot. Please try it for yourself. The warning for start radius and end radius not being the same is annoying. How do you turn it off ?
O3333(42-2456.B)
(X0Y0 IS BACK RIGHT)
(Z0 IS TOP OF PART)
(T1 = 3 DIA SHELL MILL)
(T3 = 1/4 DIA NC SPOTTING DRILL CARB)
(T7 = 3/8 DIA END MILL CARB)
N101 (3 DIA SHELL MILL)
G80G90G40G49G17G0Z0
T1 M6
G0G55X3.0Y-1.3175S2000M3T7
G43Z.1H1M8
G1Z-.005F25.0
G1X-18.5
Z0
X3.0
G0Z.1 M9
G49Z0M5
M1
N102 (T7 = 3/8 DIA END MILL CARB)
G80G90G40G49G17G0Z0
T7 M6
G0G55X-1.51Y-.375S4000M3T3
G43Z.1H7M8
G1Z-.330F8.0
G13D27I.125L2
G0G40Z.1
X-6.01
G1Z-.330F8.0
G13D27I.125L2
G0G40Z.1
X-10.51
G1Z-.330F8.0
G13D27I.125L2
G0G40Z.1
X-15.01
G1Z-.330F8.0
G13D27I.125L2
G0G40Z.1 M9
G49Z0M5
M1
N103 (1/4 DIA NC SPOTTING DRILL)
G80G90G40G49G17G0Z0
T3M6
G0G55X-510Y-2.36S7000M3T1
G43Z.1H3M8
G1Z-.065F5.0
Y-2.39
G0Z.1
X-1.51Y-2.36
G1Z-.065F5.0
Y-2.39
G0Z.1
X-2.510Y-2.36
G1Z-.065F5.0
Y-2.39
G0Z.1
X-3.510Y-2.360
G1Z-.065F5.0
Y-2.39
G0Z.1
X-4.510Y-2.360
G1Z-.065F5.0
Y-2.39
G0Z.1
X-5.510Y-2.360
G1Z-.065F5.0
Y-2.39
G0Z.1
X-6.510Y-2.360
G1Z-.065F5.0
Y-2.39
G0Z.1
X-7.510Y-2.360
G1Z-.065F5.0
Y-2.39
G0Z.1
X-8.510Y-2.360
G1Z-.065F5.0
Y-2.39
G0Z.1
X-9.510Y-2.360
G1Z-.065F5.0
Y-2.39
G0Z.1
X-10.510Y-2.360
G1Z-.065F5.0
Y-2.39
G0Z.1
X-11.510Y-2.360
G1Z-.065F5.0
Y-2.39
G0Z.1
X-12.510Y-2.360
G1Z-.065F5.0
Y-2.39
G0Z.1
X-13.510Y-2.360
G1Z-.065F5.0
Y-2.39
G0Z.1
X-14.510Y-2.360
G1Z-.065F5.0
Y-2.39
G0Z.1
X-15.510Y-2.360
G1Z-.065F5.0
Y-2.39
G0Z.1
X-1.51Y-.375
G1Z-.380F50.
G13D22I.092F12.
G0G40Z.1
G1Z-.050F50.
G13D22I.265
G0G40Z.1
X-6.01
G1Z-.380F50.
G13D22I.092F12.
G0G40Z.1
G1Z-.050F50.
G13D22I.265
G0G40Z.1
X-10.51
G1Z-.380F50.
G13D22I.092F12.
G0G40Z.1
G1Z-.050F50.
G13D22I.265
G0G40Z.1
X-15.01
G1Z-.380F50.
G13D22I.092F12.
G0G40Z.1
G1Z-.050F50.
G13D22I.265
G0G40Z.1
X0.250 Y.250
G1 Z-0.05F35.0
X0.05 Y-0.01
Y-2.46
G2 X-0.01 Y-2.52 R0.06
G1 X-16.01
G2 X-16.07 Y-2.46 R0.06
G1 Y-0.01
G2 X-16.01 Y0.05 R0.06
G1 X-0.01
G2 X0.05 Y-0.01 R0.06
G1X0.250 Y.250
G0Z1.0M9
G49Z0M5
M30
I tried using NC Plot at work today and very quickly had to go back to Discriminator.
jon
