Old 06-03-2005, 09:33 PM
MetLHead's Avatar
MetLHead MetLHead is offline
Gold Member
MetLHead is on a distinguished road
NCPlot v2 Beta 7
NC Plot v2 Beta 7 is now available for download.
available at:
http://home.wmis.net/~smartinz/softw...2/ncplotv2.htm
New for Beta 7:
Many improvements to the UI:
Toolbars have a new look and can now be rearranged. I plan to add more toolbars as well as the option to turn them on/off.
You can now change the font setting for the edit window. This is located under the Edit menu.
The viewport mouse operation has been changed:
2D views: Right mouse button pans the viewport.
Mouse wheel zooms in/out.
ISO view: Right mouse button rotates the viewport.
Shift + Right mouse button pans the viewport.
Object highlighting now displays the object properties in the status bar. For line segments this is start point, end point and length. For arcs this is start point, end point, center point and radius. The toolbar button for it has been temporarily removed, but you can still activate it through the Tools menu.
The DXF file importer has been improved. I've added a setting for a Z axis approach plane. This plane allows you to rapid the Z back down from the retract height. I've also modified the DXF settings dialog. The G-Code generator now creates code for each layer in sequence. The layer sequence can be changed on the settings dialog.
The Replace All button of the Find dialog now works the way it should - fast.
G12/G13 was not hooked up. This is now fixed.
Regards,
Scott
