If it's an older screw, every other bearing will be a slightly different color and/or size...take a close look and stagger them if the look and/or measure differently, which they will. You should have the same number of each.
How many recirculation tubes/circuits does the nut have?
Sounds like a recirculation channel may be out of alignment - you have nothing to loose here - take it (the recirc tube(s)) off if you can and take a close look to make sure it's not damaged.
Sorry to be so short - got to run.
Scott
__________________ Consistency is a good thing....unless you're consistently an idiot. |
