Old 10-25-2010, 01:00 PM
EDM_Fixer EDM_Fixer is offline
EDM_Fixer is on a distinguished road
Set your machine up for a simple MDI move.
MDI
MDI Next page.
input any safe move. x1.y1. input.
push dry run
feed rate override "0"
Press Cycle Start
Machine should drop the move into auto
turn up feed override some... it should move.
feed override back to "0"
press Feed Hold
turn off dry run
turn on the 4 functions
Wire
Water
Tension
Power
Hope your little lights work in the switch...
Press cycle start again.
If it kicks out there. More often than not the wire break switchs are not made.
You can check them in the diagnostics section. ( if you cant find um let me know and Ill get you there.)
But if the machine kicks out of cycle there (above) then one of the 4 functions required for burn cycle are not being met.
GL Jim
