I realize that I can modify the g-code file and change the depth of cut, but it would require several hours to find the exact code and modify it.
I also realize that I could probably do what I want to do if I were to generate a 2 1/2 D circuit board, but Orcad does not allow one to set the depth of the traces, or even the depth of the circuit board used.
I am hoping there is a simple solution, as I am evaluating Sheetcam at this point in time.
Thanks,
Jerry |
