Originally Posted by TROU I am trying. I have removed the control panel and am tracing the wiring. In the Control Panel Relays K800, K801, and K802 must be made for Gap Power. But only K801 is coming on by itself. When K800 is mechanically made the "Setting Check light" on the Generator goes out and the Gap power will come on. But then K802 must also be touched to latch in the Servo control from the Generator.
Thanks for replying. Just wondered if anyone had the schematics for the Tool so I don't have to hunt and peck.
TROU |
If it is just relay logic, then only problem is loose connections. One can use any contact cleaner spray & reassembly the relays & connectors to rid the problem. This was tha case with my machine.
