the head will need to be blocked and bolted to the table and the counterweight will need to be secured with the shipping bars it came with,or some will need to be made.if you need pictures i have a set of shipping bars.the battery on the cnc cpu may be dead but all that will need to be done is you will need to type in the parameters from the inside of the monitor door and reset the backlash,after powering up and letting the battery charge a bit, or replace it. The cmos battery is only on the machines with a 32mp control that has the pc built into it,most machine dont have this option. |
