Old 05-31-2005, 01:21 AM
2muchstuff 2muchstuff is offline
2muchstuff is on a distinguished road
Lay the 4 pieces on the floor like you want them. Use a tape measure and measure diagonally both ways. Adjust the frame so both diagonal measurements are the same. Tack weld the frame, flip over and tack weld the other side. Check for flatness and adjust as needed. Lay back down and finish the welding. Flip back over and finish welding the other side.
If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down.
