  #12   Ban this user!
Old 05-27-2005, 02:15 AM
strat's Avatar
strat strat is offline
strat is on a distinguished road
just an idea for the noise ...... the room i play my music in is a room inside a room theres like a 6 in gap between walls now if you took your vac and put in a box in a box it might help the biggest thing i have come to learn on sound proofing is it need to be in an air tight box sound can sneak out of a slit as small as 1/16 in .... build your box for your vac seal with silicone between each board before you screw/nail em then drop in bigger box again seal with silicone and if poss. make sure your hole for you hose is sealed also
