Old 09-22-2010, 11:53 PM
rr1021ab rr1021ab is offline
rr1021ab is on a distinguished road
When using IGF Make sure the cutter comp is set rite.If you have a .030 rad. in the corner the machine will alarm telling you tool nose radius is wring in nrc.So turn your part whithout programing the .030 radius in that corner.This only applies to fillet radius that is smaller then the radius on the tool. When you finish your profile with a .015nose radius you can insert the.030 radius with that tool. thanks ,
Hope that helps Rich
