Old 09-22-2010, 08:06 AM
mcphill mcphill is offline
mcphill is on a distinguished road
Originally Posted by mactec54 View Post
mcphill
The Fireball would not be able to cut the SMD pads accurate enough, you need a tight
linear rail/ballscrew machine & a very good spindle, to do the fine work needed for those boards, regular boards yes it could do it, but will not do SMD boards very well
NEED, or want... Sure better tolerances are desired, but are they needed? Not for my work. SMD is also a very broad topic.
This was done on my fireball:
Those are SMD pads, so you cannot say that it "cannot" be done on a Fireball. If you want to work with something really small, like QFN packages, you are right, not a good fit, but that is at the VERY small end of SMD for the hobbyist...
