My chiller pump sounds horrible as well. I was concerned it was bad and replaced it with a reman' and it still is horribly loud and grindy sounding.
All you need to do to fix the "3 PSI" issue is remove the filter screen from the bottom rear of the pump and give it a good washing, system should run about 40 PSI. I have to wash mine frequently.
