I have some funky old hardware for the David Laser Scanner... I did many scan with good accuracies but the scanning setup was heavy and mobility was an issue... So i did work on following points to improve the setup:
1- It can easily perform the scanning without calibration panel.
2- It can be easily disassembled and assembled in new location.
3-Compact in size for transportation
4- Aesthetically look beautiful
5- Electronics have all the control features
6- The complete setup is light weight.
7- Accurate and reliable
After, considering all above and lot more i was able to DIY the hardware and made the first test scan.. Attached are the pictures of my improved Hardware.. Attached you can see the scan of spray bottle .. Total 9 scans , each scan cycle took 2minutes.. Approximate height of the spray bottle is 250mm and 80mm in diameter...The alignment and stitching was a difficult part due to symmetry in the model.. However, i learn a lot in stitching the scans... further scans can be seen at:
www.my-woodcarving.blogspot.com
