Sure it helps, thanks. My setup is going to be different but it helps to see that it can be homemade with good accuracy.
I plan to use a 3ph motor with DIY VFD controlled from the PC and a belt drive. The taper will be for tool holders, not collects, since I want to make a tool changer with pneumatic drawbar, kind like the picture you posted
here
