Originally Posted by hudsonlighting Well its been a while since I updated, I managed to blow up the breakout board so I had to fit some new chips anyway...
I have made some adjustments to the program to suit the Mirac the way I have it set up. So in Mach3 when the code
T0101 M6 Appears this is saying T offset, toolnumber then M6 is tool change macro
Heres the macro:
Dim Tool As Integer
Dim OldTool As Integer
Dim NewTool As Integer
Dim MaxToolNum As Integer
MaxToolNum = 8 'Maximum positions on Automatic Tool Changer
Tool = GetSelectedTool() 'Get the toolnumber from the command e.g T0101 M6 Tool number 1
OldTool = GetCurrentTool() 'Get current tool number
Call StartToolChanger
While NewTool <> Tool
Call CheckPins
Wend
Call StopTool
SetCurrentTool(NewTool)
'//// Subroutines /////////
Sub StartToolChanger
ActivateSignal(Output3) 'Turn on output signal to turn off spindle and turn on the atc
ActivateSignal(Output4) 'Turn atc forward
End Sub
Sub CheckPins
If IsActive(Input3) And Not IsActive(Input2) And Not IsActive(Input1) Then
NewTool = 1
End If
If Not IsActive(Input3) And Not IsActive(Input2) And Not IsActive(Input1) Then
NewTool = 2
End If
If Not IsActive(Input3) And Not IsActive(Input2) And IsActive(Input1) Then
NewTool = 3
End If
If IsActive(Input3) And Not IsActive(Input2) And IsActive(Input1)Then
NewTool = 4
End If
If IsActive(Input3) And IsActive(Input2) And IsActive(Input1) Then
NewTool = 5
End If
If Not IsActive(Input3) And IsActive(Input2) And IsActive(Input1)Then
NewTool = 6
End If
If Not IsActive(Input3) And IsActive(Input2) And Not IsActive(Input1) Then
NewTool = 7
End If
If IsActive(Input3) And IsActive(Input2) And Not IsActive(Input1) Then
NewTool = 8
End If
End Sub
Sub Stoptool
DeActivateSignal(Output4) ' Stop running the ATC forward, if you don't do this the inverter will stop and the whole unit
' Will need to be turned off and on again
ActivateSignal(Output5) 'Run ATC in reverse
Sleep 3000 'Wait 3 seconds to allow the toolpost to lock in
DeActivateSignal(Output5) 'Stop running ATC in reverse
DeActivateSignal(Output3) 'Turn off output to turn spindle back on
End Sub
I've yet to test it but it works fine in VBscript. Should have a chance to test it tommorow.
The outputs corrospond to the following:
Output 3 is the ATC power contactor and Spindle Power Contactor, the Spindle Power contactor is wired to the normally closed side of the relay and and ATC power contactor is wired to the normally open side of the relay
Output 4 is the ATC Forward Relay
Output 5 is the ATC Reverse Relay |
Hi, I want to convert my Starturn5 to run with Mach3.
It uses the same LCB3 controller as your Orac does, I'm hoping the toolpost is the same.
If you would care to share your hookup schematics I would be very grateful.
I have already built a 3 axis flatbed router running under Mach3 and using a CNC4PC C11 breakout board which works very well. I was hoping to run the Starturn from the same controller.
First issue for me is the limit switches on the Z & X axis and how they are wired into the breakout board.
Can you help.
Many thanks
George
