I know with some versions you can do a repair by running the installer from the CD. You should get an option to repair the installation.
Are you sure it's not just a particular drawing causing this? If it is, try using the recover command and opening it that way. I've been using ACAD2002 for about 3 years now, and have really only had it crash for 1 reason, which happens when I copy viewports in a template I have. It's NEVER crashed for any other reason.
__________________ Gerry
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
