No you don't need to reverse the image. I printed out the pdf, transfered the image to transparent sheet (you could print directly on a transparent sheet) and transfered that to a copper-clad epoxy board. The results were acceptable, but i had to "clean" them up with a dremel. One board is 100% completed and I'm still waitng for my samples of the lmd18245t in order to complete the other two. |
