Hi Everyone,
I have a problem that I can't figure out too!
I'm running DeskNC with a Camtonics 3 axis homebuilt.
I was running 1.8 deg steppers on microstep, so .9 deg which is 400 steps per revolution.
My leadscrew is 2 turns per inch, so I set the steps per unit at 800 and no problem.
Now, I put in 2 gears to increase torque which works fine, but I can't seem to get the proper steps per inch now.
On the motor is a 12 tooth gear and on the leadscrew is a 36 tooth gear. So I figure 1:3 ratio and set the steps per unit to 2400 instead of 800.
When I try to cut a 1 inch line, it looks like maybe 1/3 that. Ok so I set it for 266.6 steps, and no change.
What am I doing wrong? I've tried all kinds of numbers and I get wierd results, from 1/3 inch to about 7".
HHHHEEEEELLLLLLPPPPP? Please.
Ken |
