When i said turning i ment grinding
seeing it's only .05
sleevers i seen at mcmaster are out .001 so they will need turned and so low end bearings are .0004 or so.(unless you're talking highend if they even make them in 14mm) finding ground tube in the size of the od of a 14mm bearing might not even be available so again you're looking at more runout if you do it yourself :P
One guy on the from here made his own spindle with a 9x20 lathe with just a normal grinder setup with .0001 runout :P
Just somthing to think about. But hay if you can find the 14mm bearings go for it sure would be alot easyer
p.s if anyone will have them give
http://www.awbearings.com/awbearings/ a call they had my p5 roller bearings when everyone else didnt :P
