Old 05-19-2005, 10:25 AM
ViperTX ViperTX is offline
ViperTX is on a distinguished road
Since the bushings are 'split' when you installed them into a hole smaller then they needed they reduced the inner diameter by some amount. As some suggested..."dry fit" one bushing on the rod to determine if you have the right bushing. If you install the bushing and the rod won't go through then the hole the bushing is mounted into is too small a diameter.
