Old 05-19-2005, 06:51 AM
DareBee's Avatar
DareBee DareBee is offline
Monkeywrench Technician
DareBee is on a distinguished road
You never did mention your application or RPM range for these bearings?
If your side load isnt insane (and you are trying to be frugal) you can stack regular "deep-groove" bearings. A deep grove is not specifically meant for side load but the are rated for some. In some cases it works really well to put in 2 or 3 (instead of 1 angular) $5 bearings and just replace when necessary.
Another option would be to design in a thrust bearing and radial bearing combo. This takes alot more physical space and machining but your bearings are still inexpensive ($5) and endplay is adjustable to zero (angular contacts can be difficult to build to zero endplay).
some food for thought - mud for mudpies
www.integratedmechanical.ca
