Old 05-18-2005, 10:17 AM
jeremyinnys jeremyinnys is offline
jeremyinnys is on a distinguished road
Well when you push the start button, it is supposed to make a rapid movement up until the fixture then feed slowly during the actual cutting. now it rapids about 2/3 the way thru the fixture before it feeds. so now i can only do 1 or 2 parts at a time instead of the usual 6. i think it's an air problem of some sort in the machine itself. air line goes up into the table somewhere. i don't want to tear it apart when i don't know about it, or even if it will do any good. the air cylinder itself seems to be working fine so i dunno...
