Originally Posted by rc-cellar
Quick question on the 5 volts. I have seperate 5V supply for my encoders. Gecko 5V are not used (470 ohm jumpers).
Would I ....
A) use One of the Gecko5V to supply all three opto's
B) or use Each(3) Gecko5V to supply the corresponding opto.
Also, I recall the max output for the encoder supply being 50mA... enough to drive a relay(?)
Oh! No! I should clarify. The 5v not specifically labeled "Enc" is from the main power supply, not the Gecko's encoder power supply.
Yeah, I was real paranoid about the Gecko's 50mA upper limit...
And I used choice B, each Gecko...corresponding opto.
