Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > 80/20, TSLOTS and other Aluminum Framing Systems
80/20, TSLOTS and other Aluminum Framing Systems Discuss Modular T-Slotted Aluminum Framing Systems here!
Old 02-17-2010, 05:30 PM
giggler is on a distinguished road
PRSalpha tslot system
I've noticed that the newer shopbots are now using tslot aluminium. The Y axis looks a different type to the X.
Does anyone know the dimensions or better still type/model of the aluminium they use?
dc
Old 12-10-2010, 04:34 PM
mikemaat's Avatar
mikemaat is on a distinguished road
Better late than never I guess...
Y is 7.75" x 4.5"
X is 6" x 1.5"
I believe that Bishop Wise Carver (BWC) creates these extrusions for them as they are not of any 80/20 profiles I have seen. They also have a new extrusion that incorporates a vrail into it. I believe BWC also makes this.
MG System 80 Help!! 4linked CNC Plasma and Waterjet Machines 32 03-31-2011 08:11 AM
Need Help!- Converting DSP controller system to Mach based system. Marwell Machines running Mach Software 0 12-19-2008 06:00 PM
can you use this cam system cob Xylotex 4 04-15-2008 08:55 AM
tslot or mdf plans Timandjulianne DIY-CNC Router Table Machines 0 03-01-2008 03:57 PM
Best Cam system under $200? Cold Fusion General CAM Discussion 8 12-30-2003 07:31 PM
