Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > 80/20, TSLOTS and other Aluminum Framing Systems
80/20, TSLOTS and other Aluminum Framing Systems Discuss Modular T-Slotted Aluminum Framing Systems here!
Old 04-14-2005, 11:50 AM
rkremser is on a distinguished road
anyone make their own t-slot linear bearings?
Just as the subject says, i'm seeing the linear bearing somewhat simple to make, has anyone tried making their own? Just am a newbie looking to keep costs down but still have a solid system.
Old 04-18-2005, 11:40 PM
Mcgyver is on a distinguished road
check out
http://www.buildyouridea.com
he makes linear bearings via hot foam -> lost foam casting. neat site.
what type of linear bearing and why do you see it as easy?
Old 04-19-2005, 12:56 AM
I should have said but in the subject i was thinking of making t-slot linear bearings just like the ones they sell, I figured if i could get the plastic milled to the right shape and simply cast or weld up a bracket equivilient to the 8020 system. Just wondering if anyone has done this
Old 06-09-2005, 11:24 AM
80/20surplus is on a distinguished road
8020 Linear Bearings
You can make your own bearings by buying your material from 8020 Surplus. They have linear bearings already made or you can purchase odd lengths and cut them to size and save cost yourself. I would suggest you check out their selection.
Old 06-09-2005, 11:48 AM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
Machined UHMW.
Making your own would be cake even without the use of a mill.
There is a new forum on linear motion in the Engineering section of this board....check it out - there are posts on this type of bearing.
I suspect this post will get moved to that location!
Scott
Consistency is a good thing....unless you're consistently an idiot.
Old 06-09-2005, 12:15 PM
JavaDog's Avatar
JavaDog is on a distinguished road
Yeah, and it would still be as poor an option as the pre-made 80/20 ones...
Now, if someone came up with a cool 80/20 bearing using skate-bearings...that could be cool!!
Check Out My Build-Log: http://www.cnczone.com/forums/showthread.php?t=6452
Old 06-09-2005, 01:54 PM
mxtras's Avatar
Silver Member
Java -
I think the 80/20 things have their place for certain folks. Some on this site seem to think the 80/20 bearings are ok:
80/20 linear bearings
Scott
Old 06-09-2005, 02:03 PM
JavaDog's Avatar
Originally Posted by mxtras
Java -
Scott
Fair enough. Still, I think something custom with Skate Bearings to be used on 80/20 could be pretty cool. Maybe I will play with some ideas...
Ballscrew Basics Swede Linear and Rotary Motion 94 09-06-2011 07:23 PM
Need help on linear bearings bbergami DIY-CNC Router Table Machines 11 05-25-2004 07:04 PM
Nylon Linear Bearings and shafting Jcadwell CNCzone Club House 7 04-15-2004 09:29 AM
Linear Guides with Teflon Bearings cely General Metal Working Machines 0 03-19-2004 05:05 PM
It seems my linear bearings don't fit... mikeschn DIY-CNC Router Table Machines 13 01-28-2004 04:45 PM
