| 80/20, TSLOTS and other Aluminum Framing Systems Discuss Modular T-Slotted Aluminum Framing Systems here! |
| T-slot table vs. cast plate I need to upgrade my table surface on my Shopbot. Right now it's an MDF vacuum fixture clamped to the main table surface which is 1/4" mild steel plate bolted to 1.5" rails. The MDF's got to go. I use a combination of edge clamping and vacuum clamping so am wondering about using either some cast aluminum tooling plate probably drilled and tapped on a grid or T-slot table. Vacuum jigs would get clamped onto the main fixture plate. Minimum dimensions are 16" x 45" max dimensions are 24" x 48". I'm mostly routing hard woods, but do a little light alu machining occasionally. Any thoughts or suggestions? |
| http://www.lowcostmetals.com/ is a good place to get cast aluminum plate. |
| I have installed a grid tapped table on my machining centre. Only once in 2 years have I wished for the T-slots. I really like it.
| Where can you find a tapped plate for a reasonable price?
__________________ Halfnutz (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| To Halfnutz Not usre what you think is a reasonable price, but I recently bought a couple of tapped aluminum plates from The Little Machine Shop.com. The holes in one are 1/4-20, not sure about the other. |
| Looking for t slot table | the4thseal | 80/20, TSLOTS and other Aluminum Framing Systems | 8 | 11-26-2011 09:53 AM |
| Trade offs between Moving Gantry and Moving Table | gregmary | DIY-CNC Router Table Machines | 11 | 04-22-2011 02:48 PM |
| DIY Z axis 0 plate. It works perfect! | balsaman | DIY-CNC Router Table Machines | 64 | 02-20-2010 11:52 PM |
| CNC laser table | owhite | Laser Engraving & Cutting Machines | 35 | 03-01-2005 11:01 AM |
| Sanity check- 6'x10' table | Zephrant | Machine Problems, Solutions , Wireless DNC, serial port | 17 | 05-13-2003 12:09 PM |
