Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > 80/20, TSLOTS and other Aluminum Framing Systems
80/20, TSLOTS and other Aluminum Framing Systems Discuss Modular T-Slotted Aluminum Framing Systems here!
Old 03-03-2005, 09:56 PM
audball22386 is on a distinguished road
T-Slot Linear Slide question
Ive been locating and designing my first machine and T-Slot aluminum extrusions seem to be the most efficient method to use. The ones i have been looking at are made by mk automation. (www.mkprofiles.com) They have their own linear slide system which is a clamp that secures two hardened rods along the t-slot. then they sell a guide roller system that are bearing that mount above the top rod and below the bottom rod. You can see what im refering to in the middle picture here (http://www.mkprofiles.com/linear_mot...ion_glides.asp)
I have a few question regarding this. MK's solution is rather expensive compared to their extrusions, so i'm looking for something more cost effective.
I also saw what 8020.net has to offer and its a slide system that surrounds the extrusion. I have seen other similiar setups, and was wondering what kind of wear and tear these bearings put on the aluminum extrusions they run on and also what type of lifespan do these bearings give before they get some sort of play in them and need replaced.
Thanks alot,
Mike
Old 03-04-2005, 02:19 AM
Hobbiest is on a distinguished road
How expensive is this design? I have seen systems like this in commercial biomed machines, and they work very well.
Stop talking about it and do it already!!!!!
slide/ rail question 2muchstuff DIY-CNC Router Table Machines 13 04-14-2005 06:25 PM
Simple linear slide design CNCadmin Linear and Rotary Motion 21 01-19-2005 04:55 PM
linear slide rods for sale in the Netherlands Tjippy DIY-CNC Router Table Machines 1 12-06-2004 02:46 PM
Inexpensive Linear Slide Assemblies? Homl DIY-CNC Router Table Machines 15 06-03-2004 02:05 AM
Linear Encoder Question Verboten Linear and Rotary Motion 5 08-30-2003 04:04 PM
