Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > 80/20, TSLOTS and other Aluminum Framing Systems
80/20, TSLOTS and other Aluminum Framing Systems Discuss Modular T-Slotted Aluminum Framing Systems here!
Old 02-03-2005, 05:09 PM
cnc2k is on a distinguished road
What to use
I am going to build a 60 x 52" router using 80/20 t-slots frame, but I not sure which type of Fasteners to use. I want to frame to hold real strong so I can get perfect cuts. Here is my question should I use corner brackets or anchor fasteners?
[IMG]www.xizou.com/images/side.jpg[/IMG] [IMG]www.xizou/imges/font.jpg[/IMG] [IMG]www.xizou.com/images/cnc router.jpg[/IMG]
Old 02-03-2005, 05:30 PM
coherent is on a distinguished road
Not quite sure what you're asking. They make specific fasteners for the extruded aluminum and are usually button head machine screws and t-slot nuts. If the entire frame is 80/20 then you'll need corner brackets or plates and the above to assemble, or you can tap the 80/20 end parts and drill an access hole for an allen wrench use the screws and t-slot nuts that way. If you use aluminum plate for the ends or gantry sides, then just tap the 80/20 ends for the button head machine screws you're using and mount the plate to the 80/20 as needed.
It all goes together fairly simple with the extruded aluminum. Hunt around the forum for photos of others. I used a welded steel table to mount an 80/20 framed machine to I built. There are some photos in the gallery under coherent. If you have any specific questions just ask!
-marc
Old 02-03-2005, 06:34 PM
ViperTX is on a distinguished road
Go with the corner plates they will give you a more rigid frame.
Old 02-04-2005, 08:11 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
I would be inclined to use both the "end tap" method as well as corner plates you are going to need the rigidity and torsional stiffness.
www.integratedmechanical.ca
