Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > 80/20, TSLOTS and other Aluminum Framing Systems
80/20, TSLOTS and other Aluminum Framing Systems Discuss Modular T-Slotted Aluminum Framing Systems here!
Old 11-03-2004, 07:25 PM
trubleshtr is on a distinguished road
great stuff to work with
Hi all, I thought I would post a few picks of the cnc machine I am currently building from aluminum profile Although I am not using 80/20 by brand name, I am using the same "t-" slot profile of a competiter, it's so easy to use, If you can put lego together you can use this stuff to build fast accurate frames.
I build automated assembly lines (or cells) with this stuff at work, and will gladly awswer any questions I can in using aluminum profiles.
ID:	3856   Click image for larger version
ID:	3857   Click image for larger version
Old 11-03-2004, 07:41 PM
Ito-Brazil is on a distinguished road
Thumbs up Big Lego
Nice! I was thinking in build my machine with this. I quoted on a allum shop , but heare in Brazil it´s so expensive... Maybe my second one!
Old 11-03-2004, 07:51 PM
Thanks, I am fortunate to work in a place where I can use end pieces for personal use!!!. I know some people will say it is expensive, but if you are considering any kind of production, or selling stuff made from your cnc machine, it will pay for itself quickley. And it looks shiney too
Old 11-03-2004, 08:00 PM
ddgman2001 is on a distinguished road
First question. How do you trim the ends dead square?
Old 11-03-2004, 08:03 PM
I use a chop saw with a non-ferrous blade ( =no kerf) so i don't get "kick back"
I use a square to set the vice jaws to the blade.
Old 11-03-2004, 08:08 PM
Deviant is on a distinguished road
How flat have you found the edges to be over X distance? I was debating on using this for a cnc mill frame. I wanted to mount linear ways to t-slots with a long t-nut.
I was just concerned on how flat/square it would be. Also have you had any problems with flex?
Thanks for the info above.
Old 11-03-2004, 08:10 PM
DEAN is on a distinguished road
Thumbs up
Very cool that they also have a line of linear motion rails. Neat stuff. I think I will make my new workstations out of this stuff.
Old 11-03-2004, 08:48 PM
I dont have the catalouge in front of me for the specs, but the coating that is on the strut is flat to within .040" , you can however skim the surfaces that you want to be "true" on a mill. My linear slides are bolted throught the profile itself, I am not done with the build yet, so far there seems to be no flex, I am however going to put more supports across the x and y axis to solve any flex during moments of inertia ,ie when i crash it into the work piece
Old 11-03-2004, 08:52 PM
This is how I mounted the linear rails.
ID:	3859   Click image for larger version
Old 11-04-2004, 12:15 AM
Gold Member
freak_brain is on a distinguished road
call 80/20 or go online and ask for their catalog. It has all the formulas in the front for calculating flex and also gives the specs for straightness. It's also free!! The example they give in their catalog is this....If you are using part number 1515 (1.5 X1.5, hence the 1515 part number) and it is suspended at each end of a 30" long piece and you put 50lbs in the center it will flex .011". the formula is like this
length of span to the 3rd power * the weight in the center / 48 * 10,200,000 * the moment of enertia
this formula is for all the weight hanging from one point in the center of the span.
The moment of inertia if different for different width pieces. You can go to www.8020.net to get the moment of inertia for the pieces you are using.
They say that it will be flat to .004 per inch of width but the thicker extrusions stay flat.
They make good stuff and if your patient you can get it all at their garage sale on eBay at
http://stores.ebay.com/8020-Inc-Gara...Q3amesstQQtZkm
also you can contact them at
info@8020.net
Take care
Allen James
  #11   Ban this user!
Old 11-05-2004, 11:52 AM
timewarp is on a distinguished road
Trubleshtr, where are you getting your extrusions from in Canada?? Online catalog?
  #12   Ban this user!
Old 11-07-2004, 01:29 AM
Arnie is on a distinguished road
Good on you Trubleshtr! Keep telling us about your machine as you go. I wish I saw that before I started. My second machine will be like that only smaller.
Great Stuff expanding insulation for lost foam molds? WayneHill Moldmaking 8 06-01-2006 06:19 AM
WOW! This is great! I'm not the only one! eford8 DIY-CNC Router Table Machines 14 07-01-2005 05:20 PM
Has anyone tried this stuff (type of delrin) dmoore764 DIY-CNC Router Table Machines 10 03-17-2005 10:58 AM
Work Holding Methods InventIt DIY-CNC Router Table Machines 13 09-14-2004 04:13 AM
What is 2.5 d work Patrick2by4 DIY-CNC Router Table Machines 9 07-05-2004 12:04 PM
